Kents RV-10 Construction Site
RV-10
Mount hardware
Swapped out the #8 screws that I had initially used to mount the diagonal strut attach angles with cap screws which are WAY easier to work with. Also swapped out some of the AN3 bolts which were a little too short in a few places.
RV-10 Home
2301
Access Covers and Fl
Aileron
Aileron Actuation
Air Conditioning
112
197
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Cabin Cover
Cabin Doors and Tran
Control System
Elevators
Empennage Attach
Empennage Fairings
Engine Mount and Lan
25
Firewall
25
Flap System
Flaps
For. Fuse Ribs, BHDS
Fuel Tanks
Fuselage Side Skins
68
149
Horizontal Stab
Horizontal Stabilize
Landing Lights
Mid Fuse Bulkheads
Mid Fuse Ribs & Bott
Outboard Leading Edg
Pitot-Static-AOA
Rear Seat Backs
Rear Spar
Rudder Pedals and Br
Seats and Seat Belts
Stall Warning System
Step Installation
Tailcone
Tailcone Attachment
41
79
Top Wing Skins
Upper Forward Fusela
Vertical Stabilizer
Wing Main Spar
Wing Ribs
Wing Tip
Wiring
