Forward fuse rib deburring and bottom skin preparation. There was some surface corrosion on the inside surface of the skin. The skin was covered with the blue vinyl while stored. I have found some corrosion like this on other pieces at their edges, this is the first time I found a trail like this across the surface under the vinyl. I used the scotchbrite wheel to take this off, it comes off easily and will be primed over.
