Bent the trailing edge of the elevator using my homemade brake. The began work on the right elevator. Separated the hinge doublers and filed them ot nest properly against the spar. clecoed and drilled the reinforcement plates, hinge doublers and platenuts to the spar. Prepared the end ribs and counterbalance ribs by smoothing the edges and fluting them. Also drilled the end rib to the counterbalance rib.
