Started off filling the edges of the cowl with fibreglass. I think I need some practice at this. Stuff runs everywhere and takes a while to set. Maybe I will read the info again. Decided to start at the rear and finish some stuff off. I started with the strobe light wire. I filed a hole in the aft most bulkhead and fitted a plastic grommet to run the wire through. I then wrapped teh wires in the plastic wrap for protection. I installe dthe platenuts for attaching the intersection fairing on the tail. I screwed teh fairing on, but when I ran the #6 tap through one ofthe platenuts, I broke it. Will have to order another one as I still have to tap the strip under teh Horizontal Stabilisers.
