Did some more on the cowl hinges. Cut the stainless steel pins and fitted the top ones. Riveted all the fairings etc to the canopy. Still needs some work, but will need some assistance to get it right. Once I had the canopy on, I then packed out the windscreen and cut it to fit. Made up some clips to hold it in place. Set up the top cowl with some tape on the edge to fill a gap I made when fitting it. Also need to work out if I am going to paint the dash or put some dash mat on there.
