Wasted most of this morning as I need the flaring tool to advance to the next stage, so I surf the net and looked at a heap of otehr builders pages. Picked the tool from Bill Keener up after lunch from Preston Boley (just brought a RV6 from the US)and started fitting the tank breather and feed pipes. Drilled some ofthe holes through the firewall. Bought a 2" hole saw for $30 to do the only 2" hole in the plane. I guess if I was closer to a builders group, I could share some of the tools, but a bit hard so far away.
