Rivited the 704 bulkhead together, drilled out the 5/8 holes for the wiring ferrules. Rivited the firewall together. Found using the "C" frame a lot easier and could get into the tight corners OK. Had difficulty with one of the flooring brackets, but drilled out the rivets and went OK.
