Daytons Web site
Date:  5-15-2002
Number of Hours:  10.00
Manual Reference:  Sec 7
Brief Description:  Aligning wing assembly
Chapter 7 Wings Date: 5/15/02 I drilled the holes for the plumb bobs and marked the rear spars. After straightening the wing assembly I clamped the rear spars to the angle on the jig. I made a fixture to draw the line on all the ribs. Next is to start aligning the pre punch skins to the ribs. Before drilling a hole I used a pick to align the rib by placing the line in the center of the hole in the pre punched skin. Then drill the rib with a #40 drill, cleco. Repeat this process for all the skins on both wings. No images available
