Installed and aligned the Ailerons to the Wings. Made up a washer insertion tool to assist Also installed the Aileron Stops on the inboard hinge assys. Used the Aileron alignment tool to get the ailerons set to neutral then used a machinists degree protractor to get the 32.4 degree set for the stops.
