Rays Web Site
RV-9A
Took photos of the basic hand tools that I have pr
This is the Avery tool Kit Plus a few other goodies that I have purchased...The Avery Kit consists of:#2X / 3X AVERY RIVET GUNS#2015 BEEHIVE SPRING#2000 QUICK CHANGE SPRING#150 AIR TOOL REGULATOR#1412 SIOUX 1/4" AIR DRILL - 3600 RPM#808 AIR TOOL OIL#1001 22" HAND RIVET & DIMPLING TOOL#10765 POLYETHYLENE DIMPLING MALLET#9430 3" AVERY HAND RIVET SQUEEZER#8005 6 PC. SQUEEZER SET MIX#8001 DELUXE DIMPLE DIE KIT WITH BLOCK#1022 3/32" POP RIVET DIMPLER#550 3/32" VISE GRIP DIMPLER#610 BUCKING BAR#615 BUCKING BAR#620 BUCKING BAR#4704 1/8" RIVET SET#4720 1/8" DOUBLE OFFSET RIVET SET#1047 FLUSH SWIVEL RIVET SET#4595 BACK RIVET SET#500 FLUTING PLIER#575 HAND SEAMER# 9885 ANGLE DRILL KIT W / 12 THREADED DRILLS#19400 C'SINK CAGE AND CUTTER(S) KIT#1027 #10 SCREW DIMPLER#330 PILOT MARKING PENS (3 EA)#1246 12" FLEXIBLE STEEL RULE#1007 RIVET GAUGE SET (4 PC)#1008 RIVET LENGTH GAUGE#58337 WISS OFFSET SNIPS - LEFT#58338 WISS OFFSET SNIPS - RIGHT#1046 SPEED DEBURRING TOOL#22022 ROYAL MULTI-BURR TOOL#1044 DOUBLE EDGE DEBURRING TOOL#3753 6" S/BRITE CUT & POLISH WHEEL#710 CURVED TOOTH FILE#757 3/32" DRIVE PIN PUNCH#758 1/8" DRIVE PIN PUNCH#25500 SWIVEL HEAD POP RIVET TOOL#12633 AIRCRAFT SHEETMETAL BOOK#4836 STANDARD AIRCRAFT HANDBOOK#2400 EMERY CLOTH ROLL#7447 SCOTCH-BRITE 5 HAND PADS MAROON#200 CLECO PLIER#1016 3/32" CLECOS (325 PCS)#1017 1/8" CLECOS (175 PCS)#2018 5/32" CLECOS (10 PCS)#2019 3/16" CLECOS (10 PCS)#1012 1/2" X 1/2" SIDE GRIPS (10 PCS)#1014 1/2" X 1" SIDE GRIPS (10 PCS)#1042 EDGE ROLLING TOOL#1065 BACK RIVETING PLATE#201 S/BRITE WHEEL KIT#38303 1/4" to 3/4" STEP DRILL#3507 3M RIVETING TAPE#40 #40 COBALT DRILLS (8 PCS)#30 #30 COBALT DRILLS (6 PCS)#21 #21 COBALT DRILLS (3 PCS)#27 #27 COBALT DRILLS (3 PCS)#19 #19 COBALT DRILLS (2 PCS)#12 #12 COBALT DRILLS (2 PCS)#1/4 1/4" COBALT DRILL (1 PC)#12X40 #40 X 12" EXTENSION DRILL#12X30 #30 X 12" EXTENSION DRILL#1100 4 PC DRILL STOP SET
RV-9A Home
624
318
