Installed air ducts using SCAT hose on engine as follows:
1. Installed engine air filter on LH side of engine using adel clamp. Connected to cold air intake on air box. Clamped SCAT hose in place with worm clamps.
2. Installed cabin air intake on RH side of engine using adel clamp. Connected to cabin heat muff on muffler. Clamped SCAT hose in place with worm clamps.
3. Connected heat muff to cabin air valve. Clamped SCAT hose in place with worm clamps.
4. Connected carb heat muff on muffler to hot air intake of air box. Clamped SCAT hose in place with worm clamps. Secured hose to battery cable using cable ties and rubber hose stand-off's.
