The new (modified) canopy attach angles were installed as follows:
1. Drilled and powder coated attach angles.
2. Stainless bolts with thin stainless washers under the heads were put in place on the attach angles, as the bolts are captive once the canopy slides are riveted.
3. Riveted slides to attach angles and temporarily bolted assemblies to fuselage longerons.
