Brief Description: Fuselage final assembly - cleco'd forward skins
Cleco'd the forward skins as follows:
1. RIveted the side skin stiffeners to the firewall fittings per Rans rivet schedule.
2. Cleco'd skins, shims, gussets, cowl attach strips, and other associated parts to the forward fuselage frame, beginning with the LH side, then RH side, and finally the top skin.
3. Cleco'd side skin inspection hole frames in place.
