1. Fitted roll bar. Mounted roll bar to fuselage, drilled and cleco'd in place. Fitted brace tube and trimmed to get roll bar perpendicular to longerons. Drilled out brace mount to 1/4".
2. Drlled forward side skin stiffeners to firewall weldments. Drilled these to #40. Will enlarge to #30 once the side skins have been removed.
3. Fitted avionics fan. Drilled mounting holes to #30 and dimpled. Fan will mount using #6 hardware during final fuselage assembly.
4. Fitted LED flood light. Mounted an LED flood light on the RH side of the fuselage to illuminate analog instruments.
5. Fitted forward pulley mounts and fuel selector. Cleco'd pulley mounts and stiffener in place. Modified fuel selector mount to accept Andair fuel selector.
6. Mounted roll servo bracket. Fitted roll servo bracket on the LH side of the fuslage. Drilled floor channels and skin stiffener to accept mount.
