Brief Description: Continued work on RH tailcone side skin
Continued working on the RH tailcone side skin as follows:
1. Cleco'd RH top skin to side skin at longeron.
2. Transfer drilled holes to #30 to facilitate more complete deburring and priming operation after disassembly.
3. Removed top skin and set aside until later.
4. Drilled a 0.246" hole 1" above the 7th rivet hole aft of the #3 bulkhead to receive the static port. Used a square on the upper surface "waterline" to locate the vertical centerline of the hole.
5. Roughed up the inner surface of the skin and the static port with scotchbrite. Bonded static port in place using 3M Scotch-Weld 2216 two-part adhesive and set RH side skin assembly aside to cure.
