Brief Description: Fitting of comm antennas on belly skin
Fitted the two comm antennas to the belly skin as follows:
1. Using the existing RH reinforcement plate as a pattern, a similar one was fabricated for the LH side. Drilled holes to replicate the pattern on the RH side.
2. Drilled mounting holes in the skins and reinforcement plates for the two RAMI model AV-17 antennas. Clipped trailing edge of the RAMI mounting plate so it would fit within the reinforcement plates.
3. Mounted nutplates on the RAMI mounting plates.
4. Disassembled parts an set aside for prep and priming.
