Assembled control sticks to the elevator torque tube as follows:
1. Assembled the control sticks to the elevator torque tube using provided hardware.
2. Modified the LH aileron bearing for the Dynon autopilot servo. An oversized washer was added to prevent the linkage from coming off in case of bearing failure.
3. Small rubber bumpers were epoxied to the stop bolts to prevent metal-to-metal contact and cushion the stop.
