Completed plumbing of brake system (less the lines going to the wheels). Used metal fittings to make the transition from the brake fluid reservoir to the cockpit side of the firewall.
Also added the input tube to the fuel flow transmitter, terminating in an elbow flare fitting for the run to the fuel selector.
