Brief Description: Fuselage center section - seat rib assembly
Completed seat rib assembly to center spar as follows:
1. Test assembled seat ribs, rear spar bulkhead, baggage ribs, and other associated compoments using clecos. Disassembled parts and set aside.
2. Cleco'd flap mechanism reinforcement plates to center seat ribs, then transfer drilled remaining holes. Disassembled parts for pre-assembly preparation.
3. Prepped an primed seat ribs, flap mechanism reinforcement plates, rear spar bulkhead and angle.
4. Assembled seat ribs to center spar using AAPQ-41 rivets.
5. Partially assembled rear spar bulkhead to the rear spar angle using CCQP-42 rivets.
6. Cleco'd rear spar bulkhead to seat ribs in preparation for baggage rib assembly.
Seat ribs attached to center spar
Rear spar bulkhead and flap mechanism reinforcements
