Tom's Rans S-19 Builders Log
S-19
Ailerons
6-20-2010
RH aileron final assembly
Completed assembly of RH aileron per Rans construction manuals as follows:
1. Enlarged all rivet holes to #30 and disassembled the aileron.
2. Deburred all holes, polished edges, buffed surfaces with scotchbrite, and cleaned with alcohol.
3. Primed the entire inside of skin and outside on rivet lines. Touched up primer on frame.
4. Cleco'd assembly together again on 4" PVC blocks and weighted with sand bags.
5. Riveted assembly per Rans rivet schedule.
6. Enlarged control horn hole to 3/16" using a reamer.
Rivet holes drilled to #30
Top skin riveted
All done
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
