Tom's Rans S-19 Builders Log
S-19
Completed wiring, plumbing + more taxi tests
More final assembly tasks as follows:
1. Joined pitot and AOA tubes from RH wing to fuselage.
2. Dressed and laced wing root wiring both in the wing and fuselage sides.
3. Lubed rod ends inside wing and installed all wing inspection covers.
4. Filled tanks again, and recalibrated the Dynon fuel gauges. The unusable fuel is no longer indicated by the gauges.
5. Performede more taxi tests (slow speed). The Dynon still needs configuration work to correct oilt temp and CHT indications.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
