Tom's Rans S-19 Builders Log
S-19
Flap / Aileron Installation 1
Began installation of flaps & ailerons as follows:
1. Constucted wing incidence fixture and checked wings for incidence and square. No adjustments were needed.
2. Drilled bolt holes in aft spar and installed attach hardware.
3. Balanced RH aileron and installed on wing. Safety wired hinge pins. Adjusted aileron push rod and installed hardware.
4. Installed both flaps and safety wired hinge pins.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
