Tom's Rans S-19 Builders Log
S-19
Mounted wings to forward carry-through spar
Mounted wings to fuselage as follows:
1. Set up metal sawhorses and sorted wing attach hardware. Removed access covers on seat ramp skins.
2. Mounted RH wing first using taper pins to assist in spar bolt hole alignment, followed by wing attach bolts. Temporarily tightened bolts.
3. Mounte LH wing.
4. Torqued nuts on tje wing bolts to 175 in/lbs.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
