Tom's Rans S-19 Builders Log
S-19
Cabin sidewall rib modification
Modified cabin sidewall ribs to accept the seat belt attatch fittings as follows:
1. Scanned, copied, and printed the cutting template for the modification. Cleco'd template in place.
2. Marked slot to be cut out on the sidewall ribs.
3. Drilled ends with #11 drill.
4. Cut slot with dremel tool. Filed edges smooth.
Ready for prep & prime.
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
