Tom's Rans S-19 Builders Log
S-19
Wiring of control sticks
Wired and installed R.A. Miller G205 stick grips on both control sticks as follows:
1. Both sticks powdercoated in a gray color matching the Rans-supplied closeout bulkhead.
2. Drilled a 1/4" hole on the inboard side of each stick near the metal collar.
3. Installed grommets in the 1/4" holes and inserted 5-conductor unsheilded wire. Installed rubber grip.
4. Wired the PTT, Trim Up, Trim Down, and A/P Disconnect fuctions. Once soldering was completed, the switch "top hat" was assembled.
5. Drilled and tapped a 4-40 hole in stick to retain "top hat" in position.
6. Installed "top hat" with a 4-40 machine screw and covered with rubber grip.
7. Performed function tests with ohmmeter.
Note color match with scrap of placstic from Rans bulkhead
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
