Tom's Rans S-19 Builders Log
S-19
RH wing - final assembly 3
Completed installation and riveting of wing skins as follows:
1. Cut opening in leading edge skin for streamline tubing that supports pitot/AOA probe.
2. Prepped and primed leading edge skin. Installed on wing frame with cleco's.
3. Riveted top skin rivet holes, beginning at the center of the main spar, working outward in a fan pattern.
4. Flipped wing assembly over to bottom side up and repeated the riveting process.
5. Installed inspection plate rings per Rans instructions.
Top side
Bottom side
Dynon pitot / AOA probe
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
