Tom's Rans S-19 Builders Log
S-19
Completed initial assembly of RH flap frame
Completed drilling and initial assembly of RH flap frame as follows:
1. Assembled ribs and other parts to spar using 3/32 clecos.
2. Drilled lower rib holes to spar to 3/32.
3. Enlarged all rivet holes to 1/8.
4. Enlarged corner holes on #1 rib and reinforcement plate to 3/16.
5. Marked parts and disassembled for deburring, edge polishing, buffing, and priming.
Almost done
Root detail
Forward corner holes drilled to 3/16
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
