Tom's Rans S-19 Builders Log
S-19
LH Aileron Frame Assembly & Skin Fitting
1. Riveted the LH aileron frame per the Rans manuals.
2. Rolled leading edge curl in the LH aileron skin using schedule 40 PVC and masking tape.
3. Fitted skin to frame using cleco's on top of spar. Leveled assembly on PVC post sections and drilled top rib holes to #40.
4. Flipped assembly over and drilled spar holes to #40, then the ribs to #40.
5. Drilled all skin holes to #30.
LH Aileron Skin Drilled to #40
Aileron Frame Detail - Control Horn
LH Aileron Drilling to #30 Complete
S-19 Home
842
Ailerons
Electrical System
Flaps
368
Landing Lights
Parts
Project
Vertical Stabilizer
