N2C...CruZer
Date:  12-1-2016
Number of Hours:  2.50
Brief Description:  Mass Balance
Finished up riveting the other outboard flaperon, really had to muscle it together to get the holes on the top of the spar to line up, ended up enlarging a good number of them to #20.
Mounted the mass balance weights, 210MM in from rivet lines. I mounted the weights centered on the 210MM line and this meant the holes drilled were not necessarily symmetrical as you need to use the existing rivet holes. Used a #30 hole finder/strap duplicator to transfer the holes. I enlarged them to A6 given the weight of the things. I also used a number stamp die on each weight and also the flaperon location so they go back to the same spot.
strap duplicator
strap duplicator
