Installed the trailing edges first and riveted those in place then went to town on the top skins and leading edges....Done!!
There are 2 rivets along the main spar you can't do because there is a bolt that interferes with allowing the rivet to get all the way into the hole. They are the very first rivet in the spar from the root and the the intersection of rib and spar to the left of the leading edge seam. You need to drill and install additional rivets midway between others for proper structural support. Then you need to reduce the size of the rivet you're going to install...which ends up being for cosmetic purposes only. I used the dremel to carefully trimm off about 1/8" of the rivet but you have to leave the stem in place so it can be pulled. The pics explain it.
