N2C...CruZer
Date:  3-16-2016
Number of Hours:  4.00
Brief Description:  Trailing Edge Access Hole
Took me several iterations of that damn bracket that supports the fuel line and the pitot lines...finally got the angles correct and got it into place.
Started riveting the wing top...I'm very happy with the inboard leading edge which has given other builders many headaches. I really played around with it when getting it together until I had it just the way I wanted it. I also added extra rivets along the lower leading edge in order to make it tight.
Will finish up the riveting tomorrow.
Finally got the angles correct
Very happy with this area
