Finished up adding nutplates to the access panel for the fuel vent line.
Laid out the access panel in the inboard trailing edge that will give me access to the fuel line connections and wiring coming out of the wing. Cut the hole, filed egses, dimpled and riveted in place with 3/32 flush rivets.
Then reinstalled all the skins back on the top of the wing including trailing edge to get ready for riveting tomorrow. However ran into a problem with the bracket I made to hold the fuel line against the rear spar. I incorrectly guessed the angle of the bracket in relation to the trailing edge skin so that the result is a small amount of the bracket sticks out below the edge of the access hole. Tomorrow I'll have to take the trailing edge off and remake the bracket with the correct angle.
