N2C...CruZer
Date:  1-28-2016
Number of Hours:  3.00
Brief Description:  Top Skin and Drilled Spar
Pulled the leading eges in with some cargo straps...GENTLY.
To correct my mistake of the the wrong overlap on the leading edge, I got one of the ribs for the other wing and set it up next to the rib with the leading edge seam. Doing this I was able to mark where to put my drill holes in between the misalligned holes...the key was to avoid the flutes and drill through good material.
Drilled the main spar.
Removed everything for more deburring and also deburred the trailing edges.
Used another rib to get locations
Ready to drill
Ready to drill
Pulled in the leading edges
