N2C...CruZer
Date:  1-16-2018
Number of Hours:  3.50
Brief Description:  Nosewheel Bearing Block Mod Completed
So I ended up making two brackets that get anchored by the AN4 bolts on the bottom and the AN3 bolt that runs horizontally, to really beef this thing up. For real overkill I added another bracket at the front that also gets anchored by the horizontal AN3 bolt (will need a longer one here, probably AN3-43A). The bracket at the front sits right up against the front of the bearing block...the rivets I used to attach the corner brackets are countersunk. To get the exact location of those holes for the horizontal bolt I had to put a rivet in the corner bracket with 1/2 of the bearing block in place and drill through the bearing block...then I had to driil that rivet out, rivet in the opposite side and repeat the process as you cannot have the opposite corner bracket in place and still be able to drill the hole...then both corner brackets get riveted, press the entire bracket into place and the bolt slides right through. Complete overkill but extremely solid and very negligible weight gain.
Side Brackets
Side Brackets
Front Overkill Bracket
