N2C...CruZer
Date:  6-12-2017
Number of Hours:  1.50
Brief Description:  Sidewall L angles
Fitted the cabin side pieces to the floor, after first giving them a dry run into the fuselage to ensure everything was in sync.
Wow did these 4 little L angles take a while...very close quarters...glad I had an angle drill that takes up no space at the head and also 12" drill bits...used them all on these little things. Clecos on and off...each hole...moving things around to drill...back to clecos...then off...
