First I riveted in the flaperon arms with the L angles.
Got the large top skin clecoed in place. Using leverage pushed the leading edges down and got in one cleco at a time.
Could not get the seam between the two leading edges to line up with the holes...my mistake. I overlapped the inboard skin on top of the outboard. The Homebuilt Help video shows it going the other way and I knew that but I thought the overlap should be front to back and inboard to outboard...big mistake, it was just enough to throw off the hole match.
What I'll do is drill and rivet the misalligned holes but drill new holes in between. These holes will have to be placed, keeping in mind where the flutes are in the nose rib.
