N144GP Lancair Super ES
Lightning (EAB-LSA)
Horizontal Stab
12-17-2012
Fit and match drilled HS brackets
need hardware shipment to finish
Adjusted position of bracket center per specific measurements from HS spar placement.
Rough fitted L and R side HS. Need the laser level from hangar and an extra set of hands to set AOI.
need AN970-3 flat washers to finish
split centering between 2 cord lines R side
L side centered per plan; verified by measurement
Lightning (EAB-LSA) Home
4066
Cowling
Elevators
Firewall forward
1070
Gear and wheels
Horizontal Stab
Move
Research, prep shop,
Vert Stab - Rudder
393
Wiring
Lancair Super ES Home
