Flying Lead RV-14A
Date:  7-13-2019
Number of Hours:  3.50
Manual Reference:  19
Brief Description:  Wing Systems Routing
Finished up the wing system witing with the exception of the GTP 59 wires. I don't want to order the whole avionics package which the GTP59 is part of, but would like to get the wiring completed.
After wiring I laid out the hole pattern and drilled the .063" reinforcement plate for the GA 35 Teardrop antenna that I will install on the left side of the empennage next to the GA 57x antenna. News to me that the GTN 650 uses the GA35 (which comes with it) and the GDU 46X needs a seperate GPS antenna (hence the GA57x)
