Brief Description: Riveted on nutplates for right wingtip
Not much to say today, got the nutplates on the right tip. For the tip lens nutplates you have to use a gun to rivet these in place. Unfortunately they sit right on the edge of the lip for the lense so it is impossible to get the set to sit flat without a special set or an unprotected backrivet set. This led to cracking off a piece of gel coat. After that I switched to MK-319-BS pull rivets.
My one and only attempt at riveting the tip lens nutplate.
view of the inside. Need to work out routing of wires before riveting on antenna.
