Fitted fin to fuselage and drilled out holes at thge very rear of the fuselage to 1/8". Removed fin and drilled out all rivet holes to 1/8". Removed skin and riveted frame with 1/8" rivets.
Removed most of the plastic protective coating from the inside of the skin. Unable to remove outside, so left to soak an a kerosene towel.
