Brief Description: Installing Cap Sender Plates, Vent and Ribs
Today, I installed the capacitance fuel sender plates, plumbed the vent and riveted in the final tank bulkhead rib. This marks the final thing to do before sealing the baffle for the Left Auxillary Tank. I will let everything cure before doing that and make sure there aren't any areas where proseal looks light. I also performed several continuity checks on the electrical hookups for the cap sender plates. Everything checked out, so let's hope it stays that way.
Final bulkhead rib in place to allow wiring up the system.
