Mike & Aneta's RV Projects
Date: 4-14-2013
Number of Hours: 8.00
Manual Reference: L Aux Tank
Brief Description: Finish Access Plate, Match-drill Stiffeners & Disa
Today, I finished the access panel in teh left auxillary tank by grinding and touching up the first cut, then creating and cutting the inner ring, then creating, trimming and match-drilling the coverplate. Once I was done with the access panel, I laid out the small rib for the ductwork landing light and marked the cutout for that. I will decide on the size of the cut once I decide on the landing lights. Then I disassembled everything and match-drilled the stiffeners in place on the skin. Now I must prepare all the miscellaneous parts, including the capacitance senders for the left aux tank, debur, scuff and dimple. Then it will be ready to go together with Proseal.
Access Panel Ring, cut and clecoed in place
Coverplate trimmed to fit and match-drilled.
Stiffeners match-drilled to the skin.
