Mike & Aneta's RV Projects
Date: 6-30-2014
Number of Hours: 3.00
Manual Reference: W-Section(22)8
Brief Description: Finished up the Flaps
Tonight, I finished riveting the trailing edges for both flaps. For the ailerons, I used Vans recommended technique to back-rivet the rivets, after initial set, to get the rivets to be "double-flush" set. This time around, because there are a lot more rivets, I decided to grind down one of my flush dimple dies to the proper angle, so I could use the pneumatic squeezer to double-flush set the rivets. It worked like a charm, and made me wish I had it done itthat way for the elevators and ailerons, as it was much quicker.
Grinding down the die.
Finished product.
Finished Flaps, sitting on top of my H Stab.
