Mike & Aneta's RV Projects
Date:  3-25-2014
Number of Hours:  3.00
Manual Reference:  W-Section(20)5
Brief Description:  Dimpling Bottom Wing Ribs
Tonight, I dimpled all the holes in all the ribs for the bottom skins on both wings using the pneumatic squeezer whenever possible. When the areas were too tight, I had to use my pull-rivet dimple dies. I also routed the static lines through the bushings I had already installed.
Static lines routed through the wing.
