Brief Description: Matchdrilling, Deburring & Installing Left Rear Sp
Today, I assembled the rear spar onto the aft portion of the right wing, then match-drilled everything, disassembled and deburred, then re-assembled and riveted it in place. Pretty repetitious work. I finished the day with only a little more to do to rivet the rest of the rear spar.
Assembling the right rear spar to rivet it into place.
After a lot of riveting, I am almost done with the right rear spar.
