Brief Description: Riveting Aft Ribs to the Main Spar
With the left wing skins removed, I decided to catch up on the right wing. I set it up on the tables and began riveting the aft ribs to the main spar. When I had finished that, I also installed the hardware that helps to hold everything on, torqued the nuts, then marked them with green torque seal paint.
