Mike & Aneta's RV Projects
Date:  7-1-2012
Number of Hours:  5.00
Manual Reference:  W-Section(13)3-4
Brief Description:  Countersinking & Wing Tie-downs
Today, I worked to countersink the remaining holes in the spar flanges, which are used to attach the leading wing skin to the spar, outboard of the main fuel tanks. Once that was done, I moved on the preparing the wing tie-downs, which involved tapping the holes to receive threaded eyes later in the build.
Lots of work to prep each spar...
One wing tie-down being match-drilled.
Second tie-down, tapped and ready to go.
