Brief Description: Trimming HS Spar Caps and Stringers
Tonight, I worked on trimming the spar caps and stringers for the Horizontal Stabilizer spar. It's messy work, but pretty easy to do with a band saw and belt sander. First, I marked and made the cuts a little short of the line. Then I used the belt sander to take off the remaining bit of material. Once all the cuts are made, I used the scotchbrite wheel to smooth the edges.
