Michaels Web Site
Sonex Standard Gear
2nd Wing Spar
Finished cutting out, deburring and smoothing the 2nd wing spar. Yay!
Finally got some shears. They work much better than the other things I was trying, but it still took an hour to cut one 12' edge.
2 more root pieces of the spar to go, then the rear spar channels, and all the spar pieces will be made.
.032 is pretty thin, but when it's all together it's +6/-3 G's!
Finally got some shears. Works much better, but still took an hour to cut one 12' edge.
The 2nd wing spar. The camera flash makes the squiggly edges look worse than they are. They're small.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
