Michaels Web Site
Sonex Standard Gear
Wiring + heater + cowl
- Put on 6 more layers of glass for the right cowl "tab"
- Attached the EGT probe's wires to the RDAC block (photo 1).
- Added the SCAT ducting for the cabin heat. I need 2 more clamps, so ordered those tonight.
Also ordered exhaust wrap for the exhaust pipes. It will keep the heat down, under the cowl.
EGT wires attached to RDAC posts.
Scat ducting added for cabin heater.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
